Convection function will not heat over 100 - everything else works
This double oven works great in all phases except the convection function on the upper oven (only one of the two with convection) will not heat above 100F. The convection fan operates and there is no indication of error but the oven will not get hotter than 100 deg., even though it does so normally in non-convection bake mode.
I am told this is likely a thermal limit switch that is somewhere inside but I don’t see them. I have seen posts saying behind the control panel but I can’t seem to remove the control panel, even though I have removed all screws I can see.
I would appreciate any help.
Thanks.
