Hello,
I have a GE Double Oven that appears to come on; however, it never heats up much less goes beyond 100-degrees. I have replaced both the Oven Control (the "brain") and the Panel Control Assembly (the outer portion containing the keypad) and still have the same result (the oven appears like it is working, but does not heat up). I have tried all settings (convection, regular, broil) and none of them heat. Thus, I am assuming I have some sort of issue getting current to the appropriate part of the oven.
The only other thing I can think of right now is that I need to replace the limit switch and/or switch limits. Is there anything else I should check?
Thank you,
Barton Shields
jbshields said:
Hello,
Thank you,
Barton Shields
I would agree on checking the power. If both ovens are not working, that would definetly be the culprit. I am sure you cut the breaker of to put in those conponents, and for sure both ovens are not working??? Tom http://www.applianceeducator.com
— Begin quote from jbshields;304562
Hello,
Thank you,
Barton Shields
Thanks for the advice and yes, you are 100% correct about GE not wanting to "share" the diagram with owners. I was actually shocked to find this out when I called their customer service line and asked them for one and they told they don’t have one. Thereafter I got on the internet and figured out that most, if not all, of the oven components are made in China; but that’s another topic.
As far as being careful goes, absolutely, I always cut the power before getting near any of the components and/or boards.
I’ll let you know how things fare after I try to figure out where the power lines are coming in from.
Thanks again for the information and the quick response.
— Begin quote from kayakcrzy;304828
I would agree on checking the power. If both ovens are not working, that would definetly be the culprit. I am sure you cut the breaker of to put in those conponents, and for sure both ovens are not working??? Tom ApplianceEducator.com
Thanks Tom, and yes, I am 100% sure both ovens are not working. Warm Regards, Barton
Good Luck!!! Let us know. Tom http://www.applianceeducator.com
