My GE cooktop works fine, except one knob simply won’t turn. I know that I either need to replace the gas valve (part 314, which has the knob stem on it), or the valve switch, (part 323, which seems to go around the stem). I can’t tell what’s keeping it from turning. Any thoughts: do I replace one or the other or should I replace both?
Link to the diagram:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214807
Thanks much in advance . . .
