My triple burner will not heat. The power light turns on but none of the single, dual, triple parts of the switch produce any response in the element. I am thinking my problem is the switch unless there is no power to the switch. Am I correct? Could there be a fuse before the switch? Is there any way to get to the switch without totally removing the cooktop? I appreciate any help you can lend.
Monty1
