Dacor cooktop - continuous sparking with gas off
Hi. I have a 2yr old Dacor cooktop that continuously sparks even when the gas controls and gas supply if off. I have tried cleaning the electrodes but the problem persists. Can anyone help me?
Check all the ignition switches and if there is nothing wrong then replace the spark module.
Gene: Thanks for the advice. I’ll work on the repair.
Keep us posted.
Gene said:
Keep us posted.
Thanks Gene. Your advice was excellent.
We just had a very similar issue with our 5-burner Bosch stovetop after a water spill: All igniters were continuously firing. Turning on one specific burner would stop the firing, but others would not do that.
Luckily after a few (10 or 15) minutes of helplessly fiddling around with the unit the problem began to clear up on its own very quickly. No repair was needed. I hope this proves helpful to someone else. :slight_smile:
