Any tips on how to remove the oven door from the wall. I do not understand how the hinges work. Any advise would be appreciated.Putting in the gasket and window inner packet will be a breeze. I located how to do this on another sight.
Thanks Dianeb
where did you find instructions as to gasket and glasspak replacement becaose that is the job I am about to start?
