Dacor MOV130S front panel not lit
I have a dacor wall oven MOV130-S. I was broiling a week ago and everything shut down. Since then the fan has been running non stop. Front panel shows no activity. Its not heating up. Only the fan runs non-stop. Does power control board or front panel display need replacement? I have tried shutting the breaker on and off. No success. Help!!!
How much does a power relay board normally cost on similar older models? I opened up the oven, did not see anything cracked or burnt circuit.
Was fixing a similar problem in older models was to replace the power relay board? Or how do I check if that board is good or front display panel is good?
I bought a display board, relay and power supply for MOV130S from ********. I hooked up display panel for now. I have a display now (which I did not before; that confirms display panel was bad). Now, when I choose the BAKE option and select desired 425F temperature, it does not warm up. Starting with default temperature of 75F, it took it 5 minutes to reach 77F in that bake option. Is there a heating panel inside somewhere that is also bad? Please assist.
thanks
Sam3
Sam,
Look for a high limit thermostat behind the control panel. It might be resettable.
Just check it for continuity. Remove the power to the oven and wires from the thermostat.
