I replaced the ERC in Nov 2008. The oven seemed to work great for about 5 months. Then I got the same F1 error code. The oven seems to work fine, but the cooling fan turns off when I turn the oven off instead of running for a few minutes as before. Then I get the F1 code again. Did I get a bad board or is there something else that could be interferring with the fan functioning properly and throwing the same code?
Related topics
Bad ERC? | 1 | 1096 | October 29, 2009 | |
oven failure code | 2 | 1163 | March 12, 2012 | |
F1 failure code - dacor | 0 | 2855 | July 11, 2008 | |
DACOR ERROR L60 - Lower Fan Bad?? | 14 | 14041 | January 24, 2016 | |
Dacor Oven Shutting off | 1 | 2716 | October 29, 2008 |
