oven failure code
My Dacor oven is displaying code F1. Three days ago I replaced the oven control board, ERC. This is exactly what happened with the original control board, ERC. Any ideas what could be causing this?
— Begin quote from hawk65;690167
Hawk,
By replacement of the ERC, you’ve pretty much isolated the situation to a faulty membrane assembly [part]AP3390946[/part]
You can try this, Disconnect power and access the control and ERC. Unplug the keypad ribbon connector, make sure there are no wires that can short to the chassis ground, and reapply power, and wait a few minutes. No F1 code, indicates a faulty keypad assembly. You could try carefully cleaning the end of the ribbon connector with contact cleaner, or rubbing alcohol, it may keep you going for a while longer.
Thanks and Good Luck,
