How do I remove the fron panel?
Open the door of the dryer, and there will be a phillips head screw holding the upper door hinge on, remove it, and the lower one, and remove the door. Then look on the other side as if there was a left handed door, and remove the screws in the same place on the other side, and then pull off the front. Tom http://www.applianceeducator.com
