Defrost thermostat changed
We replaced the Compressor start device kit (relay, overload ) on our Refrigerator. started working like a charm. although the next morning the refrigerator had tripped the GFI Breaker. WE have tired moving the defrost timer to go manually into defrost trips the breaker. Trips the GFI Breaker.
So We replaced the defrost thermostat. Still Tripping the GFI Breaker.
We are thinking about taken the refrigerator off the GFI Breaker and place other out in. My only question is if it isn’t the GFI Outlet. Should set off main breaker if still have a problem?
