Defrost Timer Location
I am unable to find the location of the defrost timer (Item 257 on diagram).
Any help would be appreciated.
Thanks.
Orlando54
I believe it’s behind the kick panel at the bottom front. You remove it to access the timer.
woodchuckie;
Many thanks. I had previously check there and didn’t see it. After your reply, I checked again and found the timer behind a large bundle of wires.
Thanks again.
Orlando54
