I got this Sub-Zero Looking Fridge from Habitat for Humanity. Has worked pretty good for 2 years.
A couple of times the fridge side gets warm.
I opened it up and saw the damper (#7914).
Just by looking at it I probably defrosted the whole unit.
Lately I have had all the symptoms.
Water in the Freezer floor.
Iced up roof.
Icemaker frooze solid - from dripping water above.
I wonder about the drain up there? Does this model have one? One forum suggested someone have it cleaned out…but said it was hard and I don’t see it in any exploded views.
The dial on the timer (part# 7405) is all beat up like
it has been dealt with before.
I have read and read and read many forums.
Basically I want to try a new timer.
Although I watch mine and it keeps moving.
Is it possible to still spin and not give a closure?
I hate to think it is intermittent. Can it, or should
it be a hard failure?
TWO different supplying companies have a #7405 timer.
One for 25, one for 45 dollars (quess which I want?)
the 25 is advertised as a 6 hour timer.
The other dosen’t say. They both have a different
…WRX09xxx Number listed for a Part Number 7405.
WHAT IF my existing timer is a replacement?
It says it is a 10 hour, non-ind, 60hz, 1/3 amp.
What might be better 6 hour or 10 hour?
Is there any real Brains or Boards in this older model?
Fridge side hold good at 25-38 degrees. Hard to get colder. The freezer (a 5 normal setting) I keep at 3 1/2 to 4 (warmer) cause it freezes great and I want to under work it of possible.
blah blah balh you ask?
What is the right timer part number? (WRX90 ???)
or based on defrost cycles, what to the Pros reccommend. 6hr or 9hr?
Total defrost has brought the unit back 3 times now.
I never realized the stress I feel knowing a whole fridges worth of food might (or is) spoiling !!!
Try finding block ice now days.
Thanks,
PATRICK
