Delongi DHE 90 dehumidifier [S/N 3 12 11 So1 P 045630]. The humidifier runs, fans and controls work, but it stopped producing water. It appears that the humidifier function (green light on panel indicating the unit is humidifying) is not operating.
I am currently working on 2 dehumidifiers with the same problem and I have to say that both fans come on and compressors but yes no water, I cant believe they both would be low on freon but I would have to go with that because if the pressure switch or thermistor were bad the fan and compressor would not turn on.
