Direction of Fan Blades on Evaporator Motor
Bought a new evaporator fan from this site, and it came in 2 pieces consisting of the motor and the fan blade.
What is the correct position for installing the fan blade back on the motor spindle - another words, which way should the blade points be facing?
Thanks.
Thanks for the respones, and no I appreciate the advice about matching the old setup. However, I must be somethng short of a dumb *** as I took out the old one to clean it and in dis-assembly - never paid attention to which way the blades went, so have never been sure about the original configutation. Then I thought about whether to test by blowing or sucking in, and again was not sure which it should be… so in any event - thanks to both of you!
