Does anyone know which direction the evaporator fan motor is supposed to turn? Just replaced burnt up motor and noticed that the shading poles on old motor are on opposite corners. Fan is turning ccw on new motor, while looking in the freezer. It seems to be drawing air towards the back. Any help would be appreciated. Thanks, Matt
Sometimes the motor can be taken apart and the armature reversed. If this is not possible, you have the wrong motor.
The fan blade must turn in the direction that cups the air and blows it away from the motor.
If it blows air away from motor, it would be blowing it away from coils and into the back cover on the refrigerator. Is that right? Or is it supposed to blow air across the coils in to the holes for the refrigerator compartment? Thanks, Matt
I have an order for the refrigerator door handle on hold so I can find out whether I can transfer the Almond insert from the old one to the replacement by simply removing two screws and transferring it. Is this a simple straightforward task as it seems to be or would I be better off ordering a new insert with the replacement handle?
