dish washer
dryer element for dishes will not heat.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=du811swpq4
See the attachment for the tech sheet
Remove power from the unit and check the heater for any physical damage.
If OK, check it with a meter. Should be around 20 to 30 ohms.
Check the thermal fuse for the heater, should be 0 ohms.
