My G.e. Dishwashers Control Panel Dose Not Light Up And Will Not Show What Mode Its Running In,or Time,some Times It Wont Work For A Day Sometime Three Days And Some Times Will Not Work At All,something Going To Let Go How Do I Go About Repairing That Mane Panel,so It Shows Lenth Of Wash Heated Dry, Short Wash,upper Rack,pots And Pans And So Forth,
Thank You
Tony,
Here is the parts breakdown
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=PDW8900L00BB
Got very lucky and was able to find a manual
http://appliancejunk.com/ge/dishwasher/31-9137.pdf
I would try the following first as it sounds like a dirty/intermittent/loose connection
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
