We started experiencing problems with our dishwasher yesterday. Couple of the buttons on the unit stopped functioning/lighting up when pressed. The unit apears to still run but some features cannot be turned on.
The following are the buttons that do not come on when pressed:
Problem is I cannot find any tech info on this unit.
GE likes to keep everything a secret.
With luck someone else will jump in with some tech info.
On most keypads a number of keys use one common line but I cannot confirm that this is the case with these two keys.
The usual way to trouble shoot is to check the keypad switches with a meter and if it checks out the control board is the most likely problem.
You could try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
