dishwasher acts like it has no power source
Our dishwasher is suddenly non-functional. It acts like it has been unplugged (it has not), the child lock is not on, the lights on the front panel are out. Any ideas on a fix without calling inthe service people again? I feel like we got a lemon. This is the 3rd major problem this kitchen aid has had in 5 years. I’ve paid alot of money for repairs and wonder if it is time to change brands all together.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5138841
Sounds like the thermal fuse is blown (Item 6 in Section2).
If it is be sure to use the new harness that comes with the fuse.
Is there a way I can test to make sure it is the fuse? Thanks
Yes.
Remove power from the unit. Unplugg one side of the fuse and measure it with a meter.
Should be 0 ohms.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
I do have a multimeter but where is the thermal fuse located? Is it the tan or black wire leading into the door switch? I see one yellow wire but it is with 4 other wires on the far right hand side of the upper control panel. I have looked at the lower control panel behind the kick plate but don’t see it there?
Look at the parts breakdown (item 6 in Section 2), main control board in the door, may be on the board or on a harness.
