The power is on at the junction box. Following advice in the forums, I have replaced the ‘Control panel’ as well as the ‘Electronic panel’ purchased from this site. It still does not power on. My next thought is it may be the ‘Thermal fuse’ that did not come with the ‘Electronic panel’ or the door switch. Any thoughts?
Could be either part but the fuse is more likely.
I would get e multimeter and check it for resistance. Should be 0 ohms.
If it is blown be sure to use the new harness that comes with it.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
