The dishwasher appears to have no power. The outlet works fine. It just stopped working one day. Any ideas, I’m pretty handy once I get headed in the right direction
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=DU945PWPQ2
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535431.pdf
A possibility is the fuse, Item 4 in the "Frame and console" section
Next would be the door latch switches
The above assumes that power is getting into the unit and it is not just a bad wire nut connection.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
— Begin quote from denman;132335
Replacement parts for WHIRLPOOL DU945PWPQ2 | AppliancePartsPros.com
hEY THERE, THE TECH SHEET FOR THIS DISHWASHER IS NO LONGER AVAILABLE HERE? ANYWAY YOU CAN SEND ME A LINK FOR ANOTHER ONE PLEASE? THANK YOU
Please see the attachment
