In The Middle Of A Cycle Our Dw Stopped Working…did A Power Reset…nothing…did A Secquence Reset Also…nothing…tried To Review All The Blogs But Could Not Find One With This Problem On This Model…whirlpool Recommened A Service Teck But I Am To Handy For This…can You Help With-out Pulling Out The Unit As My First Step??..thanks
Here is the parts breakdown
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5135518
I doubt that you will have to pull the unit.
Remove the kick plate and check that you have power to the unit
If OK and wire nuts are OK.
Remove the inner door panel and check the thermal fuse (Item 6 in Section 2).
If blown check for any signs of overheating/damage on the control board.
Be sure to use the new harness when replacing the fuse.
It is fairly common for these to blow on their own.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
— Begin quote from denman;308415
Replacement parts for WHIRLPOOL DUL300XTKT0 Undercounter Dishwasher | AppliancePartsPros.com
Thanks for the info. went into the box and found burnt connection and corrected it. Works perfect again. Thanks for the quick reply…
