Dishwasher repair
We woke to find that the washer had not run, did diagnostic ended up replacing control board and fuse. Still won’t turn on, high temp scour flashes, run test and normal light flashes also. Don’t know what’s up.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=DUL300XTKT0
Here is a tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208533399.pdf
You may have a stuck key, the tech sheet has a test procedure.
Also check that the keaypad connectors are OK
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
Thanks! I will try that. Was trying to avoid a service call, but may pay more in the long run possibly.
I have GE side by side refrigerator and I have a problem that my freezer side does not maintain the set temperature as recommended 0 degree and refrigerator side 32 degree F. Two months before I found that freezer side temperature showing about 15 degree instead of 0 degree but refrigeror side temp was according the set temp which was 32 degree and also found some ice on the wall of freezer side. I turned off refrigerator for 24 hours and started again and found that it was again maitained the set temperatures of both the side but since three days my refrigerator is giving the same problem in my freezer side and having some ice on the wall. I request to assist and giude me for this problem.
I would remove the back freezer panel and check frost pattern. If entirely frozen, you have a routine defrost problem, if not, you have refrigeration problems for a pro. to look at. post results.
