dishwasher will not run
my dishwasher will not run.all light’s work on panel.and is not flashing any code’s.thanks
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=gu1100xtlb1
Here is the tech sheet which should help you troubleshoot it further
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
Could be a door switch is not closing or it’s contacts are shot.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
