Dishwasher control panel help
I have a three year old Frigidaire Professional series dishwasher. Th left side of the control panel does not work. I would looked into getting it repaired but the cost was more than half of what the dishwasher is to buy. Can someone tell me if replacing the control panel is easy enough for a do- it-yourselfer? I have priced ordering one and repairing myself and it is the much cheaper route. If so what advice and/or directions could I have?
Here is a parts breakdown
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5158008
Here is the tech sheet
[http://frigidaireservicetips.com/pdfs/463_9.pdf](http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154580201en.pdf"]http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154580201en.pdf[/URL]
And the closest match to yours when it comes to a service manual.
[URL="http://frigidaireservicetips.com/pdfs/463_9.pdf)
Unfortunately they do not give a pin out for the keypad so you cannot really check it. Most keypads run a number of keys through a common track on the ribbon cable, that is why you loose several keys.
Your problem is either the keypad or the control board but it is a crap shoot as to which it is.
I would do the following first.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
I purchased and replaced both the switch panel and display panel on my PLD3465REC0 dishwasher. I didn’t know if it was the board or the panels and took a chance. Simply pull the old ones off and apply the new ones (clean with alcohol first).
Luckily it fixed it, (for about 18 months). Now its broken again. I’m sure it’s the switch panel again, but refuse to put another $200 into this Frigidaire POS.
