Frigidaire Dishwasher
Some of the cycle selection buttons don’t work at all (e.g., Econowash). Other buttons work only after pressing several times. What repair part do I need?
Did you ever find an answer? Im having the same problem. Thanks
You do not seem to be getting an answer, so I will give it a shot.
The original poster may still jump in but in the mean time some is better than none.
I a cannot find a control panel (keypad) schematic so cannot help with you testing it for continuity.
You may want to try the following. On most units a number of keys will use a common track on the ribbon cable. If this track cracks or makes a poor connection you loose a number of keys usually 3 or 4.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
