Dishwasher door leaking problems
I just noticed that our Maytag dishwasher is leaking at the bottom of the door. If you push on the outside of the door you can see water coming from the bottom of the door. It appears as though water is getting inside the door.
Is there anything you can do for this? Do you have to replace the entire door? Is this even possible?
