Leaking water
My Maytag dishwasher model #DWU9920AAX is leaking at the bottom of the door. The problem seems to be either the door seal (easily replaced) or the dispenser grommet. Does anyone know how to replace this part? Thanks, Houston.
This [B]Technical bulletin[/B] might help.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=27692
Do you have those part numbers for the d/w repair you completed at your friends house
