The spring on the dishwasher door have come unattached because of a rather rambunctious three-year-old who decided to see if the door would act as a trampoline if he jumped on it. Needless to say, it did not work other than to place him pretty squarely on the ground.
Anyway, we have been using the dishwasher with the springs unattached, and I finally took the kickplate off and found two springs and one retainer.
My questions are these:
Are there supposed to be two retainers (one for each spring)?
I cannot seem to work out how the retainer attaches to the spring, nor how the spring attaches to the door. It seems that the red part of the spring must go up (attaching to the door) and the retainer goes inside the spring attaching to the leg. But I am not sure. Any help?
On my electric dryer, it is becoming more prevalent that when the start button is pressed for the dryer to start, it either turns a little and stops or doesn’t turn at all, then a buzzing sound is heard from the console followed in a few seconds by a burning smell. After it cools down, for several minutes or longer, it can be started and turns for the entire timer cycle that is set - drying the clothes. However, when it is turning, it makes some excess loud humming noises … I just replaced the belt and pulleys and rollers (got the kit and just installed it) … sometimes, when it is stopped, I turn the drum and try to restart - maybe getting a buzzing again from the console - or, maybe getting some turning of the drum and eventual turning again for a full cycle - or stopping with the buzzing sound in the console again … I have been torn between either replacing the motor, the starter, or both … What is the more likely item to replace? Or, something else … I would appreciate any help!
First try rotating the drum in the correct direction. It should turn fairly easily. You may want to try this on a couple other units just to get a feel for it.
Could be it is dragging and overloading the motor.
If it turns OK then the most likely cause is the motor.
You probably either have bad motor windings, or bad bearings in the motor. Pull the drum out and check the motor. You can always bench test the motor by sticking 115 volts to motor terminals 4 & 5 and check current with an amp probe.
