My dishwasher’s door opens too quickly and guess need a new door spring? If so, how can I change it? Do I need to open the back of door panel?
I will try this weekend. Do they sell a door spring at local Home Improvement store? I found a part online but if it would be nice if I can get it tomorrow.
You can buy such parts from an appliance parts store only.
I want to convert my microwave to an outside vent. I do have the spare parts needed to do so I don’t believe. I do not have a manual. Could you tell me the parts I need. Thanks
My washer does not stop filling. Can anyone tell me the name of the part I need to order to fix this problem? Thank you.
How did you get the water to stop? Did you turn the water off or did you pull the knob to stop the timer or did you unplug the electrical cord?
- If you turned the water off, it could be several things, Water Level switch, Water Temperature Switch, Inlet solenoid valve or the Timer
- If, you pulled the plug or the power off knob and the water continued to run then the water inlet solenoid valve is the culprit but there is the possibility of multiple components
