The handle of the dishwasher is embedded up into the upper aspect of the dishwasher and although I can jiggle it down closer into it’s normal spot, it never engages. The dishwasher will therefore not close or run. I don’t know if this is a handle or a latch problem.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5138841
Here is a manual which should be useful
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4e8b0d2df77cd7e585256cd800643b6d/$FILE/KD01.pdf
You will have to remove the inside door panel to see what is going on.
Also check that the srike (latch) on the upper tub frame is OK.
