Hi,
I’m looking for help.
I have a Maytag dishwasher that is not starting. The number pad is completely dark and unresponsive to touch.
I looked on-line including this forum, and found a few manuals/tech sheets to try to diagnose the problem. One of them, said that if I was getting power to the Control Board and it still wasn’t working, to replace the control board. So i tried that. $150 later and still not working.
I checked all of the resistance readings on "page 5" of the Technical information. they all looked right except for the Thermistor (thru harnes with connector unplugged) where I got 2.5M when it said it should only be 10K. So I located the Thermistor underneath and pulled it out. I then checked the resistance where the orange and red terminals would connect on it. Now, i get a reading of just under 10K, which seems to be in the acceptable range - meaning it has not failed, I believe. I can see no nicks or cuts in the harness between the control board and the Thermistor (which maybe could give a higher resistance). i even plugged the Thermistor back in and got another "too high" reading. Not sure what to look at next. Any ideas?
I am having the same problem with a Maytag MDBH940AWS. I’ve tested everything I can think of and replaced the control board but still no luck getting the front panel LED’s to light up (the front panel buttons give the proper resistance at the control board when pressed.) Has a fix for this issue been found or is it better to just get a new dishwasher?
