Dishwasher problems
I have had this dishwasher about 2 yrs. When I push start button, the drain/cancel button lights up and goes through cycle. I will then press start and the same thing happens everytime. I flipped the breaker and waited a few minutes, pushed start button and same thing. HELP:(
Most likely the problem is a shorted key on the control panel. If you need the correct part number post the color of the control panel.
Here are the break down diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=955467&&model_id=5151156
Here is a tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535451.pdf
It has info on the keypad output.
Check it with a meter for a stuck key etc.
