My Whirlpool dishwasher model DU100XTPSB the start button has stopped working every button lights up and i can still hold down the drain button and it will drain. But when i push the start button nothing? Please help!!
Your model number seems to be short a couple digits, the following is fo a XTPB3.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5148985
Here is the tech sheet, see the attachment.
Could be the start button is shot.
Check the keypad with a meter.
Try the diagnostics.
You may want to try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
