Whirlpool Dishwasher "Start" Button does nothing
Whirlpool Dishwasher Quiet Partner II DU1100XTPSB used twice/thrice per month no longer starts automatically as soon as the "Start/Resume" button is pressed (doesn’t light up). Almost all other lights work, but not the Start/Resume light. Tried the "normal//heated dry" combination 4x, and all the lights lit up. Immediately after that, pressed "Start" and the dishwasher started washing alternating between "Normal" and "Rinse Only" cycles. I could hear the water running then the draining, it lasted for about 20 mins. Thinking that I fixed the machine after that procedure, I put a load in and had the same problem: The Start button does nothing. What’s going on and how can I fix it? It seems to be a minor problem since the dishwasher does work, but why doesn’t it start normally?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=DU1100XTPSB
The usual way to troubleshoot this problem is to check the control panel (keyboard) outputs with a meter (see the tech sheet).
If it checks out OK then replace the control board.
Still a bit of a gamble but your odds are better getting the correct part the first time.
You may also want to try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
