Dishwasher does not drain in anymode (pots/pans, normal,xxxx). Opened up the dishwasher door when it was discharging (draining). Closed door and it never restarted. Tried other modes with the same results. jpjsel
My guess would be the interlock switch (part#AP3124207) isn’t working. It is located behind the control panel.
Your model number is KUDJ230YWH0 and you can look at the part breakdown on the find parts tab.
Nat
I forgot to say that all other function of the dishwasher work. It fills with water ,washes and drys , but it does not drain.
Ok, that sounds like part of the motor may be out. With the type of pump and motor that you have in your model that would be a definate repair for me, one of the best set ups they have. The newer ones don’t clean as well to me anyway.
Nat
Purchased part number WPL 675711A from parts pro. Quick delivery! Installed today - dishwasher still does not drain. Also part 9740684 does not snap and stay on the pump. What next??? Please advise!!
jpjsel
part 9740684 does not snap and stay on the pump - when I opened the shipping box it was not attached to the pump. Running the dishwasher part 9740684 dislodges with the bottom spray wand.
Also do I need the wiring harness - is it wired different than the original? Can you supply a wring schematic for my model?
