Dishwasher trips breaker
Hello, my Jenn Air dish washer (M/N JDB6510AWP) tripped the main breaker while operating during the wash cycle. Upon investigating, I noticed if the timer dial is positioned in the end cycle time period I can hear the Timer running or if the dial is set to the Off position, the Clean LED is lit. But when setting the Timer dial to wash, the breaker trips immediately.
Is the Timer Dial failing or did the motor fail? Is there a way to test each to distinguish which one has failed? Best regards!
