Our control panel on our undercounter kitchenaid is malfunctioning. Only normal lights up and cancel. When you hit normal then start -nothing. If you hit cancel it cycles out just fine. I flipped the circuit breaker opened the control panel and cleaned the contacts. Tried it again and tested each button and each lit up. Tried normal mode and start and it started and I canceled. Loaded it that night and hit normal and start and normal lights up but no start. Once again the only lights functioning will be normal and cancel. Is it the "touch panel" itself or the control board (the brain)? thanks ,Corylus
Related topics
Please HELP!! KitchenAid dishwasher has no lights on panel | 2 | 1933 | February 24, 2015 | |
KitchenAid panel problem | 2 | 1551 | February 13, 2012 | |
KitchenAid Dishwasher does not Start | 5 | 7606 | June 27, 2011 | |
KitchenAid Dishwasher will not start | 2 | 2147 | March 12, 2012 | |
KitchenAid Dishwasher | 4 | 1825 | February 3, 2014 |
