Dishwasher Will Not Start
dICHWASHER QUIT RUNNING WITH ABOUT 2 INCH OF WATER IN THE BOTTOM. DOESN’T APPEAR TO HAVE ANY POWER AS NO LIGHTS WILL APPEAR. BREAKER HASN’T KNOCKED. ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED. THANKS
The door switch checks good as far as getting power but I dont know if it can be adjusted or not. Plus I cant find a fuse. Where should I look? Its not on the inside of the panel could it be behind the touchpad. I couldnt figure how to check behind it. Your help will surely be appreciated. Thanks
Fuse will plug into the control board either directly or by a couple short wires
Here is an example Item 6 in Section 1
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GU1200XTLT3
Here is a good link which may help you diagnose the problem
http://www.applianceaid.com/dishwash.html
