Just out of the blue our dishwasher has no power at all. We’ve checked the fuse box. We have replaced the circuit board. We’ve taken a look underneath by all the wires and cords. What else could it be?
we set the dishwasher to run this evening and went out - came home and there seems to be no power to the controls and there is some water still sitting in the bottom - breaker and power outlet seem fine. The mod number is DU1050XTPB3 Type 575-0…wasnt sure if the early advice on this post would help me also. Thanks in advance for any advice
NEW REPLACEMENT SWITCH WJ26X257DIFFERNT FROM OLD SWITCH WJ26X0257. WHAT IS THE WIRING DIG. PLEASE. THANK YOU ALLEN. MOELLER4@CTC.NET
drum frozen,not turning?
In order to provide most accurate advice we need the complete model number of the dryer and as much description on the problem as possible.
