Dishwasher won't drain
Help! My Frigidaire won’t drain after the wash cycle is complete. It was installed in 2002, I have not installed a new disposal, & the is no obstructions. I replace the drain valve & solonoid to no avail. Any ideas? :confused:
I’m an idiot Gene! I found a blockage. Appeared to be mashed potatos! It was the drain pump I replaced (for nothing). Thanks for the help!
I’m glad you were able to fix it.
mine always leaves water up to the heating element after completed cycle ,checked loop ,it looks fine,havent checked filter or pump,does it have a filter? is it that round part in bottom with vents around? insine of tub?.. help please
frank
Like mine, you might not see the obstruction. Take the hose off at both ends & try blowing air through the line. If you can’t, obviously you have a blockage. Don’t do what I did though! Drain as much water out of the unit before you disconnect it at the dishwasher! This way you won’t end up with water all over the floor & dripping into the basement!
Here is the parts breakdown
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=mde2301ayw
Unfortunately it looks like you need a new motor.
Note that there are 2 types depending on the blower in the machine.
Denman:
Thanks for the advice. I’ll use it.
JW
I have a Maytag MDG9606AWW that wouldn’t start. Dried a load this morning with no problems as usual then on the next load I pressed the Start button and it made the same hum noise at the original post and wouldn’t go.
So I thought I’d try what Jay did by taping down the door switch so I could press the start button and hand-turn the drum to get it started. It started all right, then smoke started coming out and stunk up the house. I quickly pulled the plug. I took the front off and pulled out the drum so I could make sure there wasn’t a fire inside. Seems safe now.
I’ve seen many threads blame the problem on a thermal fuse. But I’m thinking the motor is fried and must be replaced.
Am I on the right track? Anything else I should be concerned about?
Answered here: http://forum.appliancepartspros.com/dryer-repair/39830-maytag-dryer-model-mde9806ayw.html#post219084
