My dishwasher is not draining. I’ve done a few things to try and figure it out, but I could use some help as I am a novice at repair work.
I removed the drain hose from the disposal and put it in a bucket. It drained slowly, so I checked the entire hose for clogs, but didn’t find anything. I put it all back together and tried again. This time it would not drain at all, and I could hear what sounded like uncooked rice rattling around coming from underneath the machine.
I removed the filter assembly in the bottom of the tub and found lots of hard water and detergent buildup in the base, so I cleaned it all out. Next I took off the pump assembly and dismantled it, but there was no clog there. So I took out the entire housing, removed the cover and took out the motor. I saw more of the same buildup inside part of the motor, and I cleaned it all out. I put everything back together, but I have not hooked it up again in case there is something else I need to do.
Could this be caused by the impeller in the pump assembly? Is there a way to check? Could it be the motor? Any help that you could give me would be greatly appreciated!
I hope you don’t mind me jumoing in on post but since it’s exaclty related i thought it would be better thatn starting a new post.
I has the exact symptons that Steve had and replaced the drain pump today. But it still won’t drain the water, I hear the drain pumo kick on but it sounds like it is running dry, I hear no water flowing through it. I checked the hose for blockage and it is clear. Any ideas as to what else I could check? Frigidaire Model FDBB2040FC
Sorry I don’t have a disposal Gene but will try it tomorrow. Thanks for replying. I did do that before I changed the pump assembly and really nothing came out. I then blew through the hose and water did come out in other end so I don’t think there is a blockage.
On the bottom of the pump there is a exit for the water to drain. I took that hose off and found a flapper valve that was sucked in somehow causing a clog. After removing said flapper valve my dishwasher works great.
Good luck I hope this helps…
