dishwasher won't drain
the dishwasher will not drain at all. i have completely cleaned & taken apart inner workings - the only thing that is odd is that the diffuser appears to be a 1 piece on diagram - yet 2 piece in machine - with wear. i eventaully took off the bottom drain hose & the flow out the bottom was clean & constant. i blew out the line to the sink & it has no obstructions.
what do you think? my pump seems to be spinning when looking at it underneath - though it seems noisy.
thanks
