I can not start a new wash cycle.The dishwasher finished its wash cycle and the clean light is lit up but when trying to start a new wash cycle it lights the cycle light but when you push the start button it goes back to the clean light button. If i push cancel and drain it will, but can not start a new wash cycle.
my diswasher has similar aissue to what is discussed in this message, the clean light is stuck on and when pressing the start / cancel nutton nothing happens. I tripped the breaker in hopes to reset and all 3 lights were blinking, it would start a new wash cycle but had very little water pressure and the motor sounded like it was running at 50%? It was also ver noisey, any ideas?
What is the complete model number of the dishwasher?
Is the Clean light blinking or it’s steady On?
Gene thanks for responding. I am not home now to get exact model number but will send this evening. In the mean time I reset the breaker again and ran the washer through complete cycle°c and it seemed good? However when I went to run again the clean let light is on solid green and it won’t start again same problem. I did not try the breaker yet but sure it will work .
There is not much what I can do without the model number.
the model number is FDB1050REC0
Thx
Hi Gene,
I have a similar problem. I have a Whirlpool DU930PWPS0 that has the heat dry light blinking permanently. I unplugged the unit and replaced the Electronic Control (part #8546514 or W10039780). When I turned it on, it seemed to be fixed, started draining and suddenly, the dreaded blinking light started up again. I would really appreciate your help!
I’m afraid you replaced the control board with no need of it. Most likely the problem is a bad key pad. It comes as a part of the console. If you need the correct part number, post the color of it.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5135022
