Dishwasher won't start
Jennair dishwasher jdb1250awp. Some of the touch panel buttons weren’t working for a while but it still worked. Now nothing lights up and the dishwasher will not turn on. Is it the touch panel and control?
Thanks for help!!
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=Jdb1250awp
Could be either part.
The usual way to troubleshoot this is to check the key/pinouts of the control panel with a meter.
Then if it checks out OK replace the control board.
Still a bit of a crap shoot but your odds are better.
You may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
