Display constantly refreshing
We have a Maytag mfI2568aeq and the front control panel is constantly refreshing itself and I’m guessing it’s not too happy. The ice maker valve is constantly flapping, it too is not happy.
The refrigerator is not working too well but I think the freezer is working better.
Any help is appreciated!
Sorry to hear about your issue.
You’ll need a new high voltage board AP4014490
It’s on the back of the unit, remove two screws and a clear plastic cover plate. you’ll have to re-program the board. I believe the board will arrive with instructions to reprogram. If not the wiring schematic is behind the toe plate in front taped to bottom of unit i believe, and should have all that info.
good luck, hope this helps.
