Leaks water under machine during spin cycle. I assume this is only during the pumping cycle during spin.
I was going to replace Internal Drain Hose Assy #26, but wanted to test this was the leaking part. How do I test, or should I just assume this is leaking and replace. Also, can I replace by tilting machine back, and replacing from the bottom, or is necessary to disassemble cabinet.
