I apologize. I couldn’t find the model number. It’s a 10+ year old Whirlpool top loader direct drive ‘heavy duty.’
Washer won’t drain or spin. Makes a quietish ‘buzzzzzz’ sound when timer is pressed in that mode. After disassembling the cabin I took off the pump and turned the motor by hand. I then put it back together and it started pumping and lightly spinning. Then I opened the lid, it stopped. Closed the lid, and it did the ‘buzzzzz’ again. I took it apart, turned the motor by hand, back together, and it spun again. I let it pump out the water with a ‘slow’ spin, then I opened it, and closed it. ‘buzzzzzzzz’
Is this the motor?
Thanks,
Tom
