My GE front load model:WCVH6800J2WW stopped working Tuesday last week. It worked fine on previous Sunday. When you push the power button and select setting andstart it clicks numerous times (like the door is trying to lock) and then the motor runs (like it is trying to bring in or drain water). I made sure filter was clean. I tried accessing the error codes mention on tech sheet. (Pressing signal delay start signal delay start) it beeps twice then goes start into the same strips mentioned above. It start it clicks numerous times (like the door is trying to lock) and then the motor runs (like it is trying to bring in or drain water).
Any thoughts I was thinking door lock or control board. I was hoping to at least have a error code to work from. Thanks
